Säljer mitt AQ-steg då jag köpt ett SS 10k.
Knappt varmkört, riktigt kanonsteg.
![](http://213.132.112.100/images_full/85/8572800106.jpg)
Pris: 3500kr, köpare står för ev frakt.
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
