Audioque 2200D
  • S: Audioque 2200D
    Säljer mitt aq 2200d monoblock, som nytt.. knappt varmkört.
    4000:- eller bud.
    Köpare betalar ev/frakt.
    Digital Monoblock 1 ohm stable
    Input Sensitivity 0.2v-8v
    Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
    Subsonic Filter 10Hz-50Hz @ 24dB/Oct
    Output Master / Input Slave, 2 amps linkable connection
    Remote Level Control
    Clipping Display Led
    Signal to Noise Ratio 90dB
    External Fuse Rating 200 Amps, 400 Amps Linked
    Tested Voltage 14.4V
    4 ohm power @ 12V @ 1% THD 500x 1
    1 ohm power 2200 x 1
    1 ohm Power @ 16V 2500 x 1
    2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
    Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
    SM 1a i SuperStreet NW 2012.
    SM 1a i Extreme 2013.
    SM 1a i Extreme 2014.
    SM 1a i BassRace 149,9 2015.
    SM 1a i Extreme 2015.
    EM 2a i BassRace 149,9 2015.
    EM 3a i Extreme 3+ 2015.
    Re: Audioque 2200D
    SÅLT! 110717
