Tänkte sälja mina xxx basar ...
pris? vet ja inte .. ge mig ett bud !
T/S Spec XXX-15
Fs (hz) 37.10
Qms 3.910
Vas (ft.3) 2.239
Cms (mm/n) 0.078
Mms (g) 237.6
Rms (kg/s) 14.070
Xmax (mm) 39.88
Xmech (mm) 59.82
Dia (in2) 12.220
Sd (in2) 117.30
Vd (ft.3) 0.160
Qes 0.410
Re (Ohm) 4.80
Z (Ohm) 4
BL (Gauss) 25.39
Pe (watts) 8500
Qts 0.370
NO 0.760
1w/1m SPL (dB) 90.80
2.8v SPL (dB) 93.17
VC Dia. (in) 4.0
Impedance (Ohm) QVC 1
M-vd (ft.3) 0.2000
T/S Spec XXX-15
Fs (hz) 37.10
Qms 3.910
Vas (ft.3) 2.239
Cms (mm/n) 0.078
Mms (g) 237.6
Rms (kg/s) 14.070
Xmax (mm) 39.88
Xmech (mm) 59.82
Dia (in2) 12.220
Sd (in2) 117.30
Vd (ft.3) 0.160
Qes 0.410
Re (Ohm) 4.80
Z (Ohm) 4
BL (Gauss) 25.39
Pe (watts) 8500
Qts 0.370
NO 0.760
2.8v SPL (dB) 93.17
VC Dia. (in) 4.0
M-vd (ft.3) 0.2000
