Supremo Pico 1600:-
TC Sounds / Stryke HE-15 3000:-
Fs: 26 Hz
Qms: 6.0
Qes: .345
Qts: .326
Vas: 106.7 L
Re: 6 ohm
BL: 27.3 Tm
no: .529%
1W SPL: 89 dB
Cms: .145 mm/N
Mms: 257 grams
Rms: 7.0 kg/s
Xmax: 22.85 mm
Sd: 720 cm^2
Vd: 6.5L total
PEmax: ~ 2000W
3.5" p-p excursion
dual 3ohm VC
aluminum cone
Fs: 26 Hz
Qms: 6.0
Qes: .345
Qts: .326
Vas: 106.7 L
Re: 6 ohm
BL: 27.3 Tm
no: .529%
1W SPL: 89 dB
Cms: .145 mm/N
Mms: 257 grams
Rms: 7.0 kg/s
Xmax: 22.85 mm
Sd: 720 cm^2
Vd: 6.5L total
PEmax: ~ 2000W
3.5" p-p excursion
dual 3ohm VC
aluminum cone
