Har två Ampire steg som är i princip nyskick. Garanti finns kvar.
Ampire MBX200.4
4-Kanal
4x 125 Watt RMS an 4 Ohm @ 14,4 Volt
4x 200 Watt RMS an 2 Ohm @ 14,4 Volt
4x 400 Watt max. an 2 Ohm @ 14,4 Volt
2x 400 Watt RMS an 4 Ohm @ 14,4 Volt (bryggat)
2x 800 Watt max an 4 Ohm @ 14,4 Volt (bryggat)
Säkring 3 x 40A ATC
Storlek 254x64x490mm
1300:-
Ampire MB90.2
2 channel amplifier
2 Ohms stable (4 Ohm bridged)
Power supply voltage 11-15 Volt DC
Maxpower 360 watts
Power 2x 50 watts RMS @ 4Ohms
Power 2x 90 watts RMS @ 2Ohms
Power 2x 180 watts max. @ 2Ohms
Power 1x 180 Watt RMS @ 4 Ohm Power 1x 360 watts max. @ 4Ohms
High/Lowpassfilter
Input sensivity 200mV-8 Volt
S/N Ratio 93dB
Distortion 0,03% @10 watts
Fuses 1x 30A
400:-
Ampire MBX200.4
4-Kanal
Säkring 3 x 40A ATC
1300:-
Ampire MB90.2
2 channel amplifier
Maxpower 360 watts
High/Lowpassfilter
S/N Ratio 93dB
Fuses 1x 30A
400:-
