US AMP MD43
  • S: US AMP MD43
    Specs:
    100W x 4 @ 4O
    150W x 4 @ 2O
    300W x 2 @ 4O mono
    Total Harmonic Distortion: 0.03
    Frequency Response: 10~30K
    Power Band Width (Frequency Response): 10Hz - 50 KHz
    Crossover Frequency: 40~250 Hz - 15~40 dB
    Damping Factor: 400
    Dimensions: 2.5 x 10.5 x 19.75 Inches
    Fuse Rating: 30A x 3
    Power Voltage Range: 12~16V
    High efficiency Class D design(1D/2D/3D)
    Output stages utilize high-current MOSFET devices
    High speed, audio-grade components in all low-level stages
    Active Constant Current Bias Tracking Circuit
    Platinum-plated RCA inputs and connectors
    Wide range of sensitivity accepts signal from any head unit
    24dB/octave Subsonic Crossover
    24dB/octave Lowpass Crossover
    True Line Output
    Auto Bridge feature
    Short Circuit Protection
    Steget är helt nytt i kartong nypris 7500kr nu 3500kr
    finns hos kalmarbilstereo.
    Re: US AMP MD43
    någon som är sugen på ett kanon steg.
    som sagt det är helt nytt aldrig inkopplat.
