Provar att sälja min bas. det är en rejäl pjäs!
Riktigt skruvkontakter inga jävla clips.
Knappt använd
dubbla 2 ohms spolar
Spec: 6000watt peak 3000 wrms
En riktigt kraftig bas som jag har kört på ett orion d5000 steg, så den är VÄLDIGT snällt spelad.
Låter det intressant så Pma ett bud.
listpris är 4995:- men ge mig ett bud !
Phonocar 2 / 795 WOOFER 300mm 2 +2 Ohm SPL 2795 The subwoofer 2 / 795 is particularly suitable for playing high-pressure level in the low frequency range and is designed so that the tone by suffers no change. The structure of this subwoofer results from a study of the extreme mechanical requirements:
Kevlar cone in a foam-sewn suspension
and therefore resistant even in extreme Hub
4-layer voice coil
therefore high temperatures increased
double-centering of Nomex
300oz magnet with vented, full of energy ferrite-based
spoke fö ; shaped aluminum basket
For 2/795-Woofer Recon is also a kit available
Technical data:
Power. Max 3000 Watts RMS Power +3000
1500 +1500 SPL 1W/1m 88 dB
Impredanz 2 +2 Ohm voice coil 75 mm
membrane aluminum basket Cone 3 Stratus Kevlar
Dimensions diameter: 325 mm
Depth: 206 mm
http://imageshack.us/photo/my-images...sphonocar.png/
http://www.extremeaudio.de/gb/subwoo...-spl-2795.html
Knappt använd
4-layer voice coil
Technical data:
Depth: 206 mm
