hej säljer mitt Stetsom
FEATURES 6K2 D - 1 OHM
Number of Channels: 1
WRMS Power (1 ohm) to 13.8V 7900 Watts
WRMS Power (2 ohms) to 13.8V 4800 Watts
WRMS Power (4 ohms) to 13.8V 2700 Watts
WRMS Power (1 ohm) to 12.6 V 6200 Watts
WRMS Power (2 ohms) to 12.6V 4000 Watts
WRMS Power (4 ohms) to 12.6V 2300 Watts
Supply voltage: 9 to 16V
Low Pass Crossover: 50Hz to 8kHz
Total Harmonic Distortion: 90 dB
Input Sensitivity: 0.2 V
Input Impedance 20K ohms
Low Output Impedance 1 OHM
Consumption with dash 4.5 to 300A
Consumption with BASS Signal: 4.5 to 600A
Subsonic filter: 20 to 80Hz
Dimensions (H x L x H) mm: 70 x 280 x 560
Weight 8,5 Kg
Nypris 14,995kr
vi kan köra bud eller byte
NI kan pm så sliper vi alla som skriver skit här
Weight 8,5 Kg
Nypris 14,995kr
