Hejsan !
Tänkte kolla om någon kan räkna på en portad låda till min RE SE15" bas.
Ska sitta i min Audi A3.
Lite värden:
Electrical Q Value -Qes: 0.55
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.49
Free Air Resonance -Fs: 22 Hz
Equivalent Compliance -Vas: 209 liters
One-Way Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 88 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Mounting Depth - 7.75"
Mounting Hole Diameter - 14"
Overall Diameter - 15.5"
Bolt Hole Circle - 14.75"
Motor Width - 6.25"
Motor Depth - 3.25"
Basket Depth - 4.5"
Displacement - 0.17 cu. ft.
Lite värden:
Motor Width - 6.25"
Motor Depth - 3.25"
Basket Depth - 4.5"
