Re: ROBolop Design (bmw e46)
Here you can see how I mounted the cover of the speakers without seeing anything of it.
On the backside I screwed 4 aluminum plates, and when you look closely , you'll see a little pin (3mm) on your far right.
The plate is screwed tight with the same screwes the speakers are tightened with. I took about 4 to make it tight enough.
Where the little pin sits, I drew a hole, so the plate is tightened as well.
Because on the backside I’ve got 4 plates standing, I needed to mill these out.
Once I had this I could fit the plate. The plate will be inserted.
On the bottom you can see how it fits, and on top you’ll see the rings of the speakers mounted, and so you won’t see anything of the rest, simple.
The the time had come to provide everything with a layer of carbon fiber.
Provided it with a couple of layer of epoxy.
