1. Alpine 505r + stora fjärren 8000:-
2.4 st B2 HS 15 ( 2 är dragster men konat om till HS 15 ) 1500:- st
3.2 st Soundstream xxx 15" 3000:- st
4.2 st Soundstream xxx 10000 steg 8000:- st
5.8st SoundStream kithögtalare TRC.6N 700:- st
6.1 st Stinger Spv70 1700:-
7.10 st Tudor battrier 6V 155 Ah 500:- st
8. 2 st 4 kanalig soundstream steg ( ena kanale e trasig ) 800 :- st
Paket Pris :
2 st xxx basar + 2 st 10000 steg = 17000
info om basen :
15 XXX-18
Fs (hz) 37.10
Qms 3.910
Vas (ft.3) 2.239
Cms (mm/n) 0.078
Mms (g) 237.6
Rms (kg/s) 14.070
Xmax (mm) 39.88
Xmech (mm) 59.82
Dia (in2) 12.220
Sd (in2) 117.30
Vd (ft.3) 0.160
Qes 0.410
Re (Ohm) 4.80
Z (Ohm) 4 1.2
BL (Gauss) 25.39
Pe (watts) 8500
Qts 0.370
NO 0.760
1w/1m SPL (dB) 90.80
2.8v SPL (dB) 93.17
VC Dia. (in) 4.0
Impedance (Ohm) QVC 1
M-vd (ft.3) 0.2000
info om steget :
XXX-10000D
OUTPUT (WATTS):
RMS @ 4 Ohms 5500
RMS @ 2 Ohms 7500
RMS @ 1 Ohms 10000
DIMENSIONS (INCHES): 11.5 x 2.7 x 27.5
Source Voltage 12-18VDC
0704921030 // Payamo
Paket Pris :
info om basen :
15 XXX-18
Fs (hz) 37.10
Qms 3.910
Vas (ft.3) 2.239
Cms (mm/n) 0.078
Mms (g) 237.6
Rms (kg/s) 14.070
Xmax (mm) 39.88
Xmech (mm) 59.82
Dia (in2) 12.220
Sd (in2) 117.30
Vd (ft.3) 0.160
Qes 0.410
Re (Ohm) 4.80
Z (Ohm) 4 1.2
BL (Gauss) 25.39
Pe (watts) 8500
Qts 0.370
NO 0.760
2.8v SPL (dB) 93.17
VC Dia. (in) 4.0
M-vd (ft.3) 0.2000
info om steget :
XXX-10000D
OUTPUT (WATTS):
RMS @ 4 Ohms 5500
RMS @ 2 Ohms 7500
RMS @ 1 Ohms 10000
