Go Back   Bilstereoforum - Sveriges största forum för bilstereo > Köp & Sälj > Köp & Sälj - Privatpersoner
Köp & Sälj - Privatpersoner För handel mellan privatpersoner.
Old July 1st, 2014, 17:12   #1
Zzound
Rep Power: 0 Zzound is on a distinguished road
Default Skar Audio SK-4500.1D monoblock
Skar Audio SK-4500.1D monoblock. Most popular and powerful Skar Audio amplifier, ultimate in a competition grade class D Monoblock and made for only the most serious audiophiles. Featuring massive dual 1/0 gauge Power and Ground Terminals for maximum current transfer, along with a highly efficient heat sink design, you can expect maximum power output from this amplifier due to its ability to keep cool. It doesn't stop there, with the SK-4500.1D being a true competition grade amplifier, it is capable of running on 18V electrical systems at a 1 Ohm load.
Class D Digital Monoblock Amplifier
Compeition Grade
Linkable / Strappable
4 Way Protection Circuitry : Thermal, Voltage, Speaker, DC
RMS Power @ 1 Ohm : 4,900 Watts x 1 Channel (14.4v)
RMS Power @ 2 Ohms : 2,780 Watts x 1 Channel (14.4v)
RMS Power @ 4 Ohms : 1,500 Watts x 1 Channel (14.4v)
RMS Power @ 1 Ohm : 5,860 Watts x 1 Channel (16v)
RMS Power @ 1 Ohm : 7,420 Watts x 1 Channel (18v)
Frequency Response : 15~270Hz
Input Sensitivity : 6V~0.2V
Signal to Noise Ratio : 95dB
Damping Factor : 200<
Low Pass Filter : 35Hz~250hz
Subsonic Filter : 10Hz~50Hz
Bass Boost : 0dB~9dB
Phase Shift : 0~180 Degrees
Dual 1/0 Gauge Power and Ground Terminals
Working Voltage : 8.5V~18V
Remote Gain Knob Included
Line Out RCA Connection
Recommended External Fuse Rating (450Amp)
Dimensions : 650mm (Length) x 241mm (Width) x 64.5mm (Height)
SMD-AD1 / Skar Audio SK-4500.1D Results
Certified Amp Dyno Run @ 1 Ohm : 4,943 Watts at 13.85v
Un-Certified Amp Dyno Run @ 1 Ohm : 4,996 Watts at 13.85v
Dynamic Power Run (Burst) @ 1 Ohm : 6,208 Watts at 14.88v
Dynamic Power Run (Burst) @ .5 Ohm : 8,641 Watts at 15.42v
http://www.youtube.com/watch?v=w7gcDbNuZ4g
Brand new, with warranty (receipt for individuals or company).
Stockholm/Tallinn
10500SEK
Zzound is offline   Reply With Quote
S: LW Audio 6500.1 monoblock Tokken Köp & Sälj - Privatpersoner 0 May 21st, 2014 12:58
MA Audio HK2000D Class D / X Monoblock Amplifier Någon som har koll? Alvila SPL - Effekt och hög volym 16 September 19th, 2010 18:13
