Old August 17th, 2016, 19:26   #21
robolop
robolop's Avatar
Rep Power: 150 robolop is on a distinguished road
Default Re: ROBolop Design (bmw e46)
I already changed my doors to fit in the Focal 16cm
The 16cm now going to have to make room for two Focal Be 13 WS .
This is going to be a challenge because I want to let them play in a closed room to play between 10 and 14 liters. Preferably 14.
That's not going to be easy , thinking in terms of space , and then again thinking about the resonance, but i’ll manage.
Difficult is still not impossible, I’ve already done it with my previous bmw (e30)
First of all, I cut some, and cleaned up a bit.
Loosened all of the cables.
Cleared all of the cables nicely, and brought in the saw. You can see what I sawed, it’s lying on the ground.
This all looked a lot better to me.
Thats what I sawed, of course, I treated against corrosion etc. You can also see that I put on an aluminum slat L where the panel will be placed ON .
Because I needed to have a firm foundation , I milled two panels of 4mm HPL ( Trespa) . L and R.
I provided some holes for clips to secure the plate to the original position.
This fixation I use for making it a bit more easy for me . Within a few weeks you 'll begin to see that these panels will be screwed .
Then I started to make the closed room.
I made a loooooooooooooooot of silly little molds made out of cardboard , and then I drew it all on on 18mm MDF .
After a lot of milling I had this.
This all w
ill be mounted in the car
A familypicutres of the 18 parts L&R.
robolop is offline   Reply With Quote
Old August 18th, 2016, 12:08   #22
carlr
Rep Power: 258 carlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud of
Whoah - that's some nice routering skills on display right there mate!
Bygglogg BMW F36: BMW F36 SQ
Bygglogg Audi Q7: Audi Q7
Old August 19th, 2016, 12:26   #23
robolop
robolop's Avatar
Because I did not have to modify the top of the original door panel, I'll use it like this.
I still had two panels laying around, so I decided to put in the saw.
This is how it looks now..
As you can see now, I can perfectly see where the window lands once it’s rolled down.
Here you can see I’m about 3mm under the window.
Of course I need to close this room on the backside.
I’m planning of doing this with MDF of 16mm. So I took a lath of 18mm and held it against the window, and then drew a line.
What was too much I milled away , and now I have such a 5mm between the window and the MDF .
Old August 20th, 2016, 21:05   #24
robolop
robolop's Avatar
The four MDF sections that stand in the door I have now adjusted so that the window can go down like it should.
You can see at the back there is quite a difference in terms of depth. This has to do with the shape of the window.
Now I have this, I can start to adjust the original top , and fix the panel that I made.
So I can have it back in 1 piece , & I can move on to the next step.
Old August 21st, 2016, 01:07   #25
Noiseprojekt
Rep Power: 206 Noiseprojekt has a spectacular aura aboutNoiseprojekt has a spectacular aura about
Damn that looks good!!!
Noiseprojekt is offline   Reply With Quote
Old August 21st, 2016, 16:41   #26
Välljudsfantast
Rep Power: 170 Välljudsfantast is on a distinguished road
Heavy door! .
Old September 2nd, 2016, 21:37   #27
robolop
robolop's Avatar
I was able to mounten the upper part of the original panel pretty firmly on the volkern ( Trespa ) .
I was able to screw this beautiful but once all that is done, I also glued it together.
You can also see the frame 2x18mm MDF which stands on the solid core.
So the original upper part is tightened!
Then I started to make a model where the speakers can stand into
These three MDF parts are made with the uppermill.
In the upper end the speakers will come.
In the middle you see the outside where the grill will be placed in , and underneath it frame where the grill will be mounted in.
Here you can see everything together.
This is the piece of MDF where the rest will be placed on.
The right part where the peakers come to be (model-wise) fora bout 90% complete.
As you can see , it looks very blunt as it is now .
Soon you’ll see some changes
Old September 4th, 2016, 08:58   #28
carlr
I'm quite sure that is going to be awesome as always Rob!
Old September 21st, 2016, 20:52   #29
robolop
robolop's Avatar
The part which stands in the middle of the door, I made of polyester.
Of course I had to make a mold of it first. Firs I cut out the cardboard , then cut 1mm thick HPL what I still had laying around.
The advantage is that you can make a good model if you clamp it, and tighten it up.
Then taped everything, and cut the polyester to size. 3 Layers of cloth.
This is the result
You can also see that there is a rounding over the entire length .
This should now be thoroughly sanded, and then everything nicely done with filler.
Then I started to make a support for imposing the elbow. This will be the upper part.
I also have a first mold ( the 3 front) made from MDF and then milled everything.
Good thing I only have 2 doors 
Old September 23rd, 2016, 16:27   #30
misterS
Rep Power: 0 misterS is on a distinguished road
Beautiful and detailed as always!
misterS is offline   Reply With Quote
S: 2 st Digital Design 508 Lellen Köp & Sälj - Privatpersoner 0 February 9th, 2013 13:33
S: Digital design z2 lv soundigital Köp & Sälj - Privatpersoner 2 December 29th, 2012 09:50
Optimal design på bas element för SPL ? nosfaratu Allmän diskussion och frågor 48 August 22nd, 2009 14:34
