Old February 24th, 2017, 10:38   #61
robolop
Member
robolop's Avatar
Rep Power: 134 robolop is on a distinguished road
Default Re: ROBolop Design (bmw e46)
Here you can see how I mounted the cover of the speakers without seeing anything of it.
On the backside I screwed 4 aluminum plates, and when you look closely , you'll see a little pin (3mm) on your far right.
The plate is screwed tight with the same screwes the speakers are tightened with. I took about 4 to make it tight enough.
Where the little pin sits, I drew a hole, so the plate is tightened as well.
Because on the backside I’ve got 4 plates standing, I needed to mill these out.
Once I had this I could fit the plate. The plate will be inserted.
On the bottom you can see how it fits, and on top you’ll see the rings of the speakers mounted, and so you won’t see anything of the rest, simple.
The the time had come to provide everything with a layer of carbon fiber.
Provided it with a couple of layer of epoxy.
robolop is offline   Reply With Quote
Old February 24th, 2017, 17:08   #62
BMTech
Rep Power: 138 BMTech will become famous soon enough
Nuff with porn for today
BMTech is offline   Reply With Quote
Old February 25th, 2017, 21:28   #63
robolop
Member
robolop's Avatar
Being clumsy. I forgot to put hardener with the epoxy. I washed everything with aceton, and did it again. This time with hardener.
Old March 10th, 2017, 19:55   #64
robolop
Member
robolop's Avatar
In the meanwhile, I have sent the Soundstream amplifiers to England.
http://www.ampdoctor.co.uk/about-us/
I am confident in what Gordon is doing with the amplifiers.
These are some pictures he sent me.
Old March 11th, 2017, 21:30   #65
robolop
Member
robolop's Avatar
This is what happened with the Soundstream amps.
Preamp chips upgraded to give better dynamics and detail. The TL074 parts were a good chip back in the 70's but the new parts now are quieter and better sounding.
New caps to give more stable power supply rails and more stable imaging.
Mica sheets conduct heat better than polyamide sheet so the bias is stable.
Bias sensor moved so bias is stable at all temperatures and loads.
HP / HC Switch removed as it's unreliable. Stereo / mono / mixed switch replaced with a new part as it had been pulled apart and not reassembled tightly - risk of a bad connection.
Old March 12th, 2017, 07:02   #66
carlr
Rep Power: 243 carlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud ofcarlr has much to be proud of
Send a message via MSN to carlr
Gordon knows his stuff!
Bygglogg BMW F36: BMW F36 SQ
Bygglogg Audi Q7: Audi Q7
carlr is offline   Reply With Quote
Old March 26th, 2017, 22:37   #67
K_arlstrom
Rep Power: 141 K_arlstrom is on a distinguished road
Your craftmanship is as impressive as always, keep it up
K_arlstrom is offline   Reply With Quote
Old March 31st, 2017, 22:57   #68
robolop
Member
robolop's Avatar
i’ve managed to cover the doorpanels, and it worked out fine.
the carbon fiber panel where the speakers will get into, is about 90 procent finished. I need to sand and polish it a bit more for a deeper shine.
Bassreflex is also finished. As you can see I sprayed the middle piece in the same color as the moldings in the car. So I have a nice contrast and still, everything blends in nice with each other.
I need to cover the middle piece of the door, and after that, I can start mounting everything.
Old April 1st, 2017, 08:05   #69
carlr
Seriously. I'm speechless with regards to the quality level of this fabrication!
Old April 1st, 2017, 20:55   #70
Grandell79
Member
Rep Power: 85 Grandell79 is on a distinguished road
It´s fucking AWESOME!!
Grandell79 is offline   Reply With Quote
S: 2 st Digital Design 508 Lellen Köp & Sälj - Privatpersoner 0 February 9th, 2013 13:33
S: Digital design z2 lv soundigital Köp & Sälj - Privatpersoner 2 December 29th, 2012 09:50
Optimal design på bas element för SPL ? nosfaratu Allmän diskussion och frågor 48 August 22nd, 2009 14:34
