Go Back   Bilstereoforum - Sveriges största forum för bilstereo > Köp & Sälj > Köp & Sälj - Privatpersoner
Köp & Sälj - Privatpersoner För handel mellan privatpersoner.
Old August 24th, 2012, 13:35   #1
yeppe
yeppe's Avatar
Rep Power: 123 yeppe is on a distinguished road
Default Ampire MBX200.4 & MB90.2
Har två Ampire steg som är i princip nyskick. Garanti finns kvar.
Ampire MBX200.4
4-Kanal
4x 125 Watt RMS an 4 Ohm @ 14,4 Volt
4x 200 Watt RMS an 2 Ohm @ 14,4 Volt
4x 400 Watt max. an 2 Ohm @ 14,4 Volt
2x 400 Watt RMS an 4 Ohm @ 14,4 Volt (bryggat)
2x 800 Watt max an 4 Ohm @ 14,4 Volt (bryggat)
Säkring 3 x 40A ATC
Storlek 254x64x490mm
1300:-
Ampire MB90.2
2 channel amplifier
2 Ohms stable (4 Ohm bridged)
Power supply voltage 11-15 Volt DC
Maxpower 360 watts
Power 2x 50 watts RMS @ 4Ohms
Power 2x 90 watts RMS @ 2Ohms
Power 2x 180 watts max. @ 2Ohms
Power 1x 180 Watt RMS @ 4 Ohm Power 1x 360 watts max. @ 4Ohms
High/Lowpassfilter
Input sensivity 200mV-8 Volt
S/N Ratio 93dB
Distortion 0,03% @10 watts
Fuses 1x 30A
400:-
SM 1a i SuperStreet NW 2012.
SM 1a i Extreme 2013.
SM 1a i Extreme 2014.
SM 1a i BassRace 149,9 2015.
SM 1a i Extreme 2015.
EM 2a i BassRace 149,9 2015.
EM 3a i Extreme 3+ 2015.
yeppe is offline   Reply With Quote
Old August 31st, 2012, 04:12   #2
yeppe
yeppe's Avatar
Default Re: Ampire MBX200.4 & MB90.2
Upp
Old September 14th, 2012, 02:09   #3
yeppe
yeppe's Avatar
upppppppppppppp
Old September 21st, 2012, 06:35   #4
yeppe
yeppe's Avatar
Finns kvar .
Old October 5th, 2012, 04:10   #5
yeppe
yeppe's Avatar
Upp .
Old January 12th, 2013, 01:23   #6
yeppe
yeppe's Avatar
JÄPP .
Old February 23rd, 2013, 17:52   #7
yeppe
yeppe's Avatar
Sålda 130222
S: Ampire kitsystem REA ca 50% Nyberg Köp & Sälj - Butiker och Leverantörer 3 January 25th, 2012 09:45
Ampire MBX200.4 yeppe Allmän diskussion och frågor 10 September 4th, 2011 20:02
S: Erbjudande på ny serie från ampire Nyberg Köp & Sälj - Butiker och Leverantörer 1 July 5th, 2011 19:32
