Säljes 15" subzero bas samt En passiv bas från earthquake på 15"
Allt helt nytt i kartong och kvitto.
Pris:7000:-
Specifications:
Model: Subzero-15
EAN: 1-411368-975937
Fs: 24Hz
Max Power: 2500W
RMS Power: 1250W
Mechanical Xmax = 4" peak to peak
Electrical Xmax = 2" peak to peak
Impedance: dual 4Ω
Sensitivity:89.7dB
Dual Nomax / Romax spider
8 gauge speaker terminals
Patented PSP terminal
BL 70% @ Xmech
Dimensions:
Diameter: mm
Cut-Out Diameter: 369mm
Mounting Diameter: 240mm
TS Parameters:
TS data obtained using the VI-BOX high power system. Specs measured @ 100watt rms. Standard TS is done @ 1-3 watt, insufficient for obtaining true data in a high excursion modern woofer.
Fmd= 3.0000 KA
Qmd= 1.0000
Flp= 8.0000 KA
Qlp= 2.0000
Znom= 8.0000 Ohm
Revc= 7.8000 Ohm
Sd= 8.90000E-02 M²
Mmd= 3.541806E-01 Kg
Rtvc= 2.500000E-01 °C/W
Xcoil= 3 In
Xmax= 3.17500E-02 M
Krm= 3.54970E-02 Ohm
Erm= 8.0000E-01
Kxm= 2.091940E-01 H
Exm= 6.770000E-01
Rms= 4.4866 N-S/M
Mms= 3.694390E-01 Kg
Cms= 1.146000E-04 M/N
Vas= 4.5787 Ft³
Fo= 24.4600 Hz
Qms= 12.6551
Qes= 0.3095
Qts= 0.3021
BL= 37.8262 T-M
Levc= 1.24090E-02 H
SPLo= 89.7098 dB
No= 5.877000E-01 %
SLAP passiv bas info:
SLAPS enables the transfer of high amplifier power into low frequency output. Since the device does not have to fight against increasing pneumatic pressure in a closed cabinet or over-excurt close to a port tuning frequency. SLAP has no annoying port noise and enables deep bass from a compact volume. SLAPS promotes the dynamics of a small system in which a closed enclosure design has difficulties. In a closed cabinet design the pneumatic loading of the woofer increases as a function of its travel, this causes compression. SLAPS technology possesses none of these limitations.
SLAPS allows tuning below 10hz making any worries about tuning frequency superfluous.
Sold and priced per piece.
Features:
Key System Benefits
Coupled with almost all woofers, SLAPS increases output without added amplifier power or enclosure volume
Suitable for high output needs where space is limited
User-tunable adjustments can be set to match a range of vehicle requirements and musical preferences.
Key Installation Benefits:
Installs just like a subwoofer
Slim-mount design is only 3-inches deep
No increase over existing sealed subwoofer enclosure sizes
Easy tuning for quick adjustments
Specifications:
Model: SLAPS-15
EAN: 1-121368-975980
Flad pistonisk membran
SWE (Super Wide Edge) kantophæng med en højde på: 44 mm
Nødvendigt frirum på hver side af enheden: 90 mm
Monteringsdybde: 44 mm
Ydre diameter: 420 mm
Udskæringshul: 388 mm
Nedfræsning: 6 mm
TS Parameters:
Fs: 13 Hz (Free Air Resonance)
Cms: 0,000199996 Meter / Newton (Mechanical Compliance)
Mms: 0,7165 kg (Total moving mass it includes the air load)
Qmd: 7 (Mechanical losses, 7 is typical for passive radiator)
Sd: 0,0764 (Piston areas measured from peak of surround to peak of surround)
Ev frakt betalas av köparen
Frontpage | Contact | SitemapCopyright © 2014 Auralinear - All rights reserved
Pris:7000:-
Specifications:
Model: Subzero-15
Fs: 24Hz
Max Power: 2500W
RMS Power: 1250W
Impedance: dual 4Ω
Sensitivity:89.7dB
BL 70% @ Xmech
Dimensions:
Diameter: mm
TS Parameters:
Fmd= 3.0000 KA
Qmd= 1.0000
Flp= 8.0000 KA
Qlp= 2.0000
Znom= 8.0000 Ohm
Revc= 7.8000 Ohm
Sd= 8.90000E-02 M²
Xcoil= 3 In
Xmax= 3.17500E-02 M
Erm= 8.0000E-01
Kxm= 2.091940E-01 H
Exm= 6.770000E-01
Rms= 4.4866 N-S/M
Vas= 4.5787 Ft³
Fo= 24.4600 Hz
Qms= 12.6551
Qes= 0.3095
Qts= 0.3021
BL= 37.8262 T-M
Levc= 1.24090E-02 H
SPLo= 89.7098 dB
No= 5.877000E-01 %
Features:
Key System Benefits
Specifications:
Model: SLAPS-15
Nedfræsning: 6 mm
TS Parameters:
