Digital Designs S2 stora kantiga modellen
Specs
- Input Sensitivity 0.2V - 8V
- Variable High Pass Filter 20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
- Variable Low Pass Filter 50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
- Clipping Display LED
- Tested Voltage 14.4
- Tested THD 1%
- Model S2a
- Cont Power at 4 ohm 390W x 2ch
- Cont Power at 2 ohm 700W x 2ch
- Damping Factor >1000 @ 4 ohm
- Cont Power at 1 ohm 1100W x 2ch
- Cont Power at 4 ohm Mono 1400W x 1ch
- Cont Power at 2 ohm mono 2200W x 1ch
- Dynamic Power 3000W x 1ch
- Efficiency thru Output >65%
- Dimensions - mm 620 L x 247 W x 55.9 H
- Dimensions - inches 24.41 L x 9.72 W x 2.20 H
- Signal to Noise >100 dB
nån liten repa kanske men ser för övrigt bra ut.
4000:-
Specs
- Tested THD 1%
- Model S2a
4000:-
