Behöver mer power!
Säljer därmed av mitt goa LW Audio 6500.1 steg
Specifications
Powerful 6500W Monoblock (Daily Use) Version
RMS Power at 1 Ohm (13,6V) 6588w x 1
RMS Power at 1 Ohm (16V) : 6750W x 1
RMS Power at 2 Ohms Linked (16V) : 12,900W x 1
1 Ohm stable circuitry
Linkability : Output Master and Input Slave
24dB/Oct Variable Crossover
Input Sensitivity : Adjustable from 200mV ~ 6V
Subsonic Filter : Adjustable from 10Hz ~ 60Hz
Variable Bass Boost : 0 ~ 18dB
Variable Low Pass Filter : 35Hz ~ 250Hz
2 Zero(0) Gauge Power Input Terminals
Signal to Noise Ratio : >90dB A-Weighted @ 2Vrms
Damping Factor : >210
Tested Voltage & T.H.D : 14.4V / 16.0V & Less than 1% T.H.D
Operating Voltage : DC10V ~ 16V
Dimension : (L)600mm X (W)290mm X (H)74mm
Pris: 8000:- och finns i haninge
Skick som nytt!
Specifications
Skick som nytt!
