Skulle vara sjukt tacksam om nån gjorde en "grundberäkning" till mina basar i seperata lådor
nya lådorna har volymen 50L st utan bas å port, skulle vilja ha avstämningen runt 45hz borde bli bra för lite alltiallo bas, lyssnar mer åt dunk, dance, party än metal
Zachry XLNT-1200
Artnr. 932804
Free air resonance(Fs) 29,89 Hz
Electrical Q factor(Qes) 0,41
Mounting cutout(mm) 275 mm
Mechanical Q factor(QMS) 5,67
Voice coil inductance(Le) 3,03 MH
Mounting dept 135mm
Equivalent volume(Vas) 61,27 liter
Impedance(Z) 4ohm
Total weight 5,8kg
Suspension compliance(Cms) 0,18 mm/N
Force factor(Bl) 15,32 N/A
Magnet diameter 156 mm
Moving mass(Mms) 155,73 g
Voice coil resistance(RDC) 3,3 Ohm
Power RMS 300W
Total Q factor(Qts) 0,38
linear excursion(Xmax) 7,5 mm
Sensitivity(SPL) 88 dB
Frame material Al
Cone area(Sd) 491 cm2
Power MAX Cone material 600 Watt
Air gap height 9 mm
Outher diameter 315 mm
Surround material Gummi
Pice coil diameter 52 mm
Frequence range 20-1500 Hz
Voice coil wire material Cu
Voice coil layers 4
Magnet mass 1,77 kg
MVH Alvila
Zachry XLNT-1200
Artnr. 932804
Mounting dept 135mm
Impedance(Z) 4ohm
Total weight 5,8kg
Power RMS 300W
Frame material Al
Air gap height 9 mm
Voice coil layers 4
Magnet mass 1,77 kg
MVH Alvila
