ROBolop Design (bmw e46)
  • #61
    Re: ROBolop Design (bmw e46)
    Here you can see how I mounted the cover of the speakers without seeing anything of it.
    On the backside I screwed 4 aluminum plates, and when you look closely , you'll see a little pin (3mm) on your far right.
    The plate is screwed tight with the same screwes the speakers are tightened with. I took about 4 to make it tight enough.
    Where the little pin sits, I drew a hole, so the plate is tightened as well.
    Because on the backside I’ve got 4 plates standing, I needed to mill these out.
    Once I had this I could fit the plate. The plate will be inserted.
    On the bottom you can see how it fits, and on top you’ll see the rings of the speakers mounted, and so you won’t see anything of the rest, simple.
    The the time had come to provide everything with a layer of carbon fiber.
    Provided it with a couple of layer of epoxy.
    • #62
      Nuff with porn for today
      • #63
        Being clumsy. I forgot to put hardener with the epoxy. I washed everything with aceton, and did it again. This time with hardener.
        • #64
          In the meanwhile, I have sent the Soundstream amplifiers to England.
          http://www.ampdoctor.co.uk/about-us/
          I am confident in what Gordon is doing with the amplifiers.
          These are some pictures he sent me.
          • #65
            This is what happened with the Soundstream amps.
            Preamp chips upgraded to give better dynamics and detail. The TL074 parts were a good chip back in the 70's but the new parts now are quieter and better sounding.
            New caps to give more stable power supply rails and more stable imaging.
            Mica sheets conduct heat better than polyamide sheet so the bias is stable.
            Bias sensor moved so bias is stable at all temperatures and loads.
            HP / HC Switch removed as it's unreliable. Stereo / mono / mixed switch replaced with a new part as it had been pulled apart and not reassembled tightly - risk of a bad connection.
            • #66
              Gordon knows his stuff!
              Bygglogg BMW G20: BMW G20 SQ (Ny!)
              Bygglogg BMW F36: BMW F36 SQ
              Bygglogg Audi Q7: Audi Q7
              • #67
                Your craftmanship is as impressive as always, keep it up
                • #68
                  i’ve managed to cover the doorpanels, and it worked out fine.
                  the carbon fiber panel where the speakers will get into, is about 90 procent finished. I need to sand and polish it a bit more for a deeper shine.
                  Bassreflex is also finished. As you can see I sprayed the middle piece in the same color as the moldings in the car. So I have a nice contrast and still, everything blends in nice with each other.
                  I need to cover the middle piece of the door, and after that, I can start mounting everything.
                  • #69
                    Seriously. I'm speechless with regards to the quality level of this fabrication!
                    • #70
                      It´s fucking AWESOME!!
                      • #71
                        Deeper shine? Serious? Looks awesome.
                        Mini Cooper goes Pioneer
                        http://www.bilstereoforum.se/showthread.php?t=36531
                        Volvo V50
                        http://www.bilstereoforum.se/showthread.php?t=34708
                        Sponsorer som håller mig flytande:
                        Pioneer, Stinger
                        • #72
                          He is insanely serious.
                          • #73
                            I isolated the doors.
                            Before I started, I checked again if no water got into the door when it rains. So I went to the car was, and focusses on the doors with the lance.
                            At home I took the hose and put it onto all rubbers and cracks. In both cases I didn't see a single drop in the doors. Not bad for a bmw of 18years old.
                            I already noticed before there was only 1 little sloth (2cm) in the door where there could be a waterfailure.
                            I chose Focal Bam XXXL https://www.focal.com/en/car-audio/c...ation/bam-xxxl
                            This box contains 3 square meters of damping material. Normally you can do a whole car with this, but when I was finished on the doors, I used almost everything.
                            • #74
                              Thx dude's...........
                              • #75
                                Doorpanels are about 90% finished now. Here and there I’m planning of doing a small detail which will be original and cool.
                                Later more about that…
                                Here an original doorpanel like they come from the factory.
                                These were the doorpanels I modified once. The bottom part was fully adjusted to make way for the 16cm Focal speakers.
                                EVO1.
                                Here some pictures about how they will look now.
                                Evo 2 (there will not come an Evo 3)
                                These are some pictures when the white lighting is on, when the door is opened.
                                On pictures it looks like it’s blue, but in real life, it’s white…
                                There’s a LED strip underneath the door, in the storage compartment and behind the door handle.
                                The one behind the door handle needs some more modification, I don’t like it that way
                                You can also see the white lighting coming out of the bass reflex.
                                The orange inner lighting was also finished, but it wasn’t like I wanted it to be. The orange strip I’ve used was TOO orange comparing with the orange interior lighting (original BMW)
                                This one is a bit more red. So some work is planned to get those strips out, and make them more red with a marker.
                                This will take a couple of hours, but when it’s all done and merges into the rest of the lighting, I’ll be very pleased.
